NyxCharon
Recently, I came across a Linux package called Xen. Xen is a hypervisor which basically means it's sole purpose is for running VM's. What makes Xen a little different is that you have to use a Xen kernel, however it also opens up a realm of new tools for you to use, especially VGA passthrough.
VGA passthrough makes use of Intel's VT-D or AMD's IOMMU protocol. What this basically means is I can assign hardware to my VM. This then allows me to setup a full gaming rig inside of a VM. I've been using this setup for about 2 months now, and it works great.
If you want to learn more about Xen, especially for this purpose, there are multiple guides on how to do it. I'm going to do my own writeup eventually, but they all for the most part work the same way. I'd link them, but i'm not sure of the policy on linking to other forums threads.
If curious, this is the hardware I used:
Case: Zalman Z11
CPU: Intel i5-3570
Mobo: Asrock Z77 Pro3
Cooler: Kuhler H20
RAM: 8Gb Corsair Vengeance
Graphics: Asus DC2 2GB HD7850
PSU: APEVIA 680W
OS: Fedora 17
Before anyone ask, you have to have a motherboard and a cpu that supports this, period. All the Intel K series chips will not work, and finding a good mobo for this is tricky. In terms of graphics cards, AMD ones work with little effort. Nvidia Quadro cards have decent success, but other Nvidia cards usually dont work at all.
My experience with all of this so far has been a bit tricky, but very rewarding. Long gone are the days of rebooting my computer so I can play games in Windows. Sound is a bit of an issue, but I've made due. I have passed through my mobo sound to the VM, and then bought a USB soundcard for Linux. I then run a Y cable from both into my speakers. I've also passed through a USB controller for my VM, so now the ports on the top of my case work for windows.
In terms of performance lag, there isn't any. Mouse input can degrade sometimes, but I use a separate mouse via the USB ports i passed through with great success. I'm still running most of the games I play on High/Ultra with no frame drops.
If anyone has any questions about xen, performance, etc feel free to ask.
Case: Zalman Z11
CPU: Intel i5-3570
Cooler: Kuhler H20
PSU: APEVIA 680W
OS: Fedora 17
