stefan-west1
Hi all I have the ud3h z77 motherboard by gigabyte. Unfortunately if you have read my previous posts. The old on wouldn't boot. It would flash on for a second and then turn off. After an rma with scan try replaced the gpu and motherboard. However now this one is doing exactly the same. I've only had the thing a few days!
I can only assume I need to update the bios to try and solve the problem. Assuming I can get it to boot again the problem I've got is I can download the latest bios update from the gigabyte website but whenever I try to open it, it comes up with its only compatible with 32bit windows 7 when I have 64bit. How can I update the bios ony system?
Is it simply a matter of placing the file on a flash drive and booting from it to solve the problem?
Any help is much appreciated. Thanks all
