Virssagòn
Unigine Valley 1.0
How To Submit!
Take a Screenshot of:
- your score from EXTREME HD PRESET --> Idk, but I think you need at least a 1080p resolution... (in app or from saved HTML file)
- 2 instances of cpu-z (cpu tab and memory tab)
- 1 instance of gpu-z
- notepad with name, computerforum, date (and not really needed, your specs)
ATTENTION: See that you take a picture from the overclocked speed, and not the underclocked power saving speed!!!
Example:
Scores:
Rules: Follow the right instructions to submit your score or you won't be added!
DOWNLOAD
Valley Benchmark is a very nice new benchmark from the developers of Heaven Benchmark, which was already pretty known as a very good scaling benchmark. The Bench includes awesome landscapes, walkthroughs from the forest, topview of beautiful snowed mountains, snakeways through the grass of the valley,...
All that tests your gpu to his limits, every unstable overclock will be eliminated by this program and will not be able to receive his score. This stress on your GPU makes it an extreme hardware stability test.
Features listed on guru:
- Extreme hardware stability testing
- Per-frame GPU temperature and clock monitoring
- Advanced visual technologies: dynamic sky, volumetric clouds, sun shafts, DOF, ambient occlusion
- Multi-Platform support for Windows, Linux and Mac OS X
- 64 000 000 square meters of extremely detailed, seamless terrain
- Procedural object placement of vegetation and rocks
- The entire valley is free to be explored in interactive fly-by or hike-through modes
- User-controlled dynamic weather
- Support for stereo 3D and multi-monitor configurations
- Benchmarking presets
- Command line automation support
- Highly customizable reports in CSV format
Happy Benchmarking!
How To Submit!
Example:
Scores:
DOWNLOAD
Happy Benchmarking!
