Junglist0682
Just did a restart and then this appeared.
If you're able to reinstall windows with recovery discs, you can get a hard drive will under $100. If you arent able to do that then it will not be worth purchasing windows and a hard drive.
It seems you got an am3/am2+ board, so maybe just upgrade to a phenom II x4 955/965.
They are still pretty good and will give you a nice improvement over your current.
You can get it very cheap nowadays.
The only thing that I'm worried about is the max TDP of your board, can you give me the model number?
