Wont boot from Iso!
ivtec
banned
Hi guys: i´m trying to boot an Linux ISO that i made, either from a CD or USB but my laptop sony vgn- 195ep won't see the cd or USB,upon restart i enter the bios and change the drive it has dvd but not usb selection,i change to dvd but no avail.And the USB Stick it seems that it turns off the usb stick during booting ,.I´m i missing something? thanks
How are you putting the ISO on the disk/USB drive?
I suggest you use this to make it bootable.
http://rufus.akeo.ie/
Make sure you select "Create bootable disk image using = ISO Image"
Thanks nevakoaza; i did download the Iso from Linux mint web site suggest link one of the USA links,then i used the dvd burner dragged the linux iso from the desk top to the dvd burner,
the USB i did download iso same way to the desktop then i used win Unetbootin program then after download it told me to restart the laptop i did but it did not reboot with the stick rather turns off the usb stick and boots normally with winxp on the cd and stick.Thanks.
You can't just drag and drop iso files to a burner. You must use burning software that will write ISO files to cd/dvd.
Thanks, I was able to make the CD ISO after some struggle and waisted a coupler DVD,but well allways learning,also on the medle of the struggle
i did lost the Win xp but i was able to install Debian GNU/Linux 7.0.0-wheezy, also could make an USB boot stick a piece of advise not to use Unetbootin this one is peice of crap never could do nothing with it rather use
Pen Drive and it will save you time and patience.
now that i'm set can you please tell me how to config. thwe wireless
i have these on screen
Editing Wireless connection 1
SSID
Mode ad-hoc
band auto
BSSID
Device Mac Adress
Clone Mac Adress
What exactly are you trying to do?
Ok john apreciate you interest in helping ,as i said i downloaded the
Debian gnu/linux linux 7.0.0 distro and it is running great but i,m trying to learn for now i have my Sony Vaio Connected with a internet cable but i want to configure the wireless connection.but don]t know how,if you know i would apreciate giving me instructions
when i open the Vpn connections have configure VPN connection
SSID
Mode ad-hoc
band auto
BSSID
Device Mac Adress
Clone Mac Adress
My first question is do you have the wireless card configured? One issue with Debian is they only use free software, on my vaio it requires a proprietary driver or at least that is what I found when I had Debian 6.0 installed which I had to manually install since Debian would not offer that. To find out which wireless card chip you have type:
Let us know the output.
Yeah, that's true, by default. But if you just add contrib and non-free repos to /etc/apt/sources.list then you can access all the software, including proprietary software and drivers. In my case, since i use "testing", it looks like this:
Code:
deb http://ftp.us.debian.org/debian/ testing main contrib non-free
Thanks DMGrier.
v 03)
00:1f.1 IDE interface: Intel Corporation 82801DBM (ICH4-M) IDE Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 03)
00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller (rev 03)
00:1f.6 Modem: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Modem Controller (rev 03)
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI M9+ 5C61 [Radeon Mobility 9200 (AGP)] (rev 01)
02:01.0 CardBus bridge: Texas Instruments PCI7420 CardBus Controller
02:01.2 FireWire (IEEE 1394): Texas Instruments PCI7x20 1394a-2000 OHCI Two-Port PHY/Link-Layer Controller
02:01.3 Mass storage controller: Texas Instruments PCI7420/7620 Combo CardBus, 1394a-2000 OHCI and SD/MS-Pro Controller
02:02.0 Network controller: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection (rev 05)
02:04.0 USB controller: NEC Corporation USB (rev 43)
02:04.1 USB controller: NEC Corporation USB (rev 43)
02:04.2 USB controller: NEC Corporation USB 2.0 (rev 04)
02:08.0 Ethernet controller: Intel Corporation 82801DB PRO/100 VE (MOB) Ethernet Controller (rev 83)
frank@debianverizon:~$
Hi there is anybody home!
i made an iso of mint14 mate KDE and tryied to install on vgn a 195ep
but it won't pass the logo i installed the iso cd on my other pc Lenovo and it installed good so much so i kept it instead of Ubuntu 1204LTS for now.
what other distro you think will install on this machine and will run the wireless easy
i would hate to go back to win xp but if i don't get it running wireless have no other option,specs of Sony vaio bellow thanks.
http://www.cnet.com/laptops/sony-vaio-vgn-a195ep/4507-3121_7-31107241.html
I see that you have an old laptop. Try to install lubuntu linux which is lighter version of ubuntu and is intended to be used on older PCs.
Link: http://lubuntu.net/
pu300 thanks i'll give it a try,
let you know that when i start to install Debian 7.0.0 wheezy it ask me for
IPI2200 card files tells me to put in a usb of flopy disk with this file i put it on the usb stick and put it in the usb port but since upon start the usb is turned off while the system is booting,also there is no drive for a usb in the bios setup,only hhd and dvd.so the only way is the dvd iso.
Hi it's me again i couldn't get wireless to work on debian7 so i tried Lunbuntu but it won't install won't pass the logo, same with linuxmint14 so i went to Xunbuntu and it installed good but i can't get the wireless to work either wire cable works great, sorry if i bother you too much,it seems i can not go back to winxp cause i have an blue screan error
0x0000001, (0x000077b,0x00000002 some like this when i have a chance i'll post pic.
i think it has to do with drivers, i already did update drivers from sony,but no avail.
now i have to stick wirh Linux Distro and this what i want in the first place since winxp will end sup next year,
Ipw2200 that work have to find a Linux Distro that runs on this old Laptop and that supports the sony drivers.
^try this
http://askubuntu.com/questions/192414/lubuntu-12-04-installation-trouble
A note about the drivers. I am guess that you need to install the common files for your wireless card. I'll give you an example for a broadcom wifi card.
If you do not have synaptic package manager, install it through the software center you might also be able to install it with
sudo apt-get install synaptic
Open synaptic package manager and search broadcom. Install the package broadcom-sta-common. Then open additional drivers and see if there is a new wireless driver for you to use. You might need a reboot for that driver to show in that menu.
If you do not have a broadcom wireles card this will not work. Check what vendor makes your wifi adapter.
  • Screenshot from 2013-06-02 09:59:47.jpg
^try this
I don' have broadcom, i have synaptic already installed,
this what i took from ---network wireless tools
Networking .
used to manipulate the Linux Wireless Extensions. The Wireless Extension is an interface
allowing you to set Wireless LAN specific parameters and get the
specific stats.
Networking (multiuniverse)
This package contains the wireless regulatory database used by the Central
Regulatory Database Agent (CRDA) to configure wireless devices to operate
within the radio spectrum allowed in the local jurisdiction.
This regulatory information is provided with no warranty either expressed or
implied. Only Linux drivers which use cfg80211 framework can make use of the
regulatory database and CRDA.
Networking ( multiuniverse)
6tunnel allows you to use services provided by IPv6 hosts with
IPv4-only applications and vice versa. It can bind to any of your IPv4
or IPv6 addresses and forward all data to IPv4 or IPv6 host.
It can be used for example as an IPv6-capable IRC proxy.
I have no idea what distro you are using anymore, but here's the page for your wifi card for debian:
http://wiki.debian.org/ipw2200
Which says you just need to
apt-get install firmware-ipw2x00 wireless-tools
and reboot.
ThanksNyxCharon: Now i intalled XUNBUNTU and i like it but it suffers the same problem no wireless,i tryed a few distros mint14 kde,and nadia ,Lunbuntu don't install,
Debian 7,wheezy and now Xunbuntu both work on my machine but no wireless and no Flash player. and those items are very inportant to me,
Here is some info from the terminal maybe this will help you figuer it out and help me.Thanks in advance, and remenber i'm not very savey on this things i do it more by blind fold and some times i get it done don't ask me how, no schooling all i know had to hit my head meny time to get where i wanted to go,hope you understand.
dmesg [options]
Options:
-C, --clear clear the kernel ring buffer
-c, --read-clear read and clear all messages
-D, --console-off disable printing messages to console
-d, --show-delta show time delta between printed messages
-E, --console-on enable printing messages to console
-f, --facility restrict output to defined facilities
-h, --help display this help and exit
-k, --kernel display kernel messages
-l, --level restrict output to defined levels
-n, --console-level set level of messages printed to console
-r, --raw print the raw message buffer
-s, --buffer-size buffer size to query the kernel ring buffer
-T, --ctime show human readable timestamp (could be
inaccurate if you have used SUSPEND/RESUME)
-t, --notime don't print messages timestamp
-u, --userspace display userspace messages
-V, --version output version information and exit
-x, --decode decode facility and level to readable string
Supported log facilities:
kern - kernel messages
user - random user-level messages
mail - mail system
daemon - system daemons
auth - security/authorization messages
syslog - messages generated internally by syslogd
lpr - line printer subsystem
news - network news subsystem
Supported log levels (priorities):
emerg - system is unusable
alert - action must be taken immediately
crit - critical conditions
err - error conditions
warn - warning conditions
notice - normal but significant condition
info - informational
debug - debug-level messages
frank@VGN-A195EP-PT:~$ lsmod
Module Size Used by
tifm_sd 17566 0
joydev 17393 0
snd_intel8x0 33455 3
snd_ac97_codec 110213 1 snd_intel8x0
ac97_bus 12642 1 snd_ac97_codec
snd_pcm 80916 2 snd_intel8x0,snd_ac97_codec
snd_seq_midi 13132 0
snd_rawmidi 25424 1 snd_seq_midi
snd_seq_midi_event 14475 1 snd_seq_midi
pcmcia 39826 0
radeon 733914 2
snd_seq 51592 2 snd_seq_midi,snd_seq_midi_event
snd_timer 28931 2 snd_pcm,snd_seq
snd_seq_device 14172 3 snd_seq_midi,snd_rawmidi,snd_seq
psmouse 96718 0
tifm_7xx1 12937 0
snd 62218 13 snd_intel8x0,snd_ac97_codec,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
tifm_core 15040 2 tifm_sd,tifm_7xx1
ipw2200 146210 0
libipw 46732 1 ipw2200
cfg80211 178877 2 ipw2200,libipw
ttm 65344 1 radeon
soundcore 14635 1 snd
serio_raw 13027 0
yenta_socket 27428 0
pcmcia_rsrc 18367 1 yenta_socket
drm_kms_helper 45466 1 radeon
snd_page_alloc 14115 2 snd_intel8x0,snd_pcm
lib80211 14040 2 ipw2200,libipw
pcmcia_core 21511 3 pcmcia,yenta_socket,pcmcia_rsrc
drm 197641 4 radeon,ttm,drm_kms_helper
sony_laptop 39681 0
parport_pc 32114 0
mac_hid 13077 0
rfcomm 38139 4
bnep 17830 2
bluetooth 158479 10 rfcomm,bnep
ppdev 12849 0
i2c_algo_bit 13199 1 radeon
asus_laptop 23693 0
sparse_keymap 13658 1 asus_laptop
input_polldev 13648 1 asus_laptop
shpchp 32265 0
lp 17455 0
parport 40930 3 parport_pc,ppdev,lp
usbhid 41937 0
hid 77428 1 usbhid
firewire_ohci 40180 0
firewire_core 56940 1 firewire_ohci
e100 36289 0
crc_itu_t 12627 1 firewire_core
frank@VGN-A195EP-PT:~$ iwconfig
lo no wireless extensions.
eth1 IEEE 802.11bg ESSIDff/any
Mode:Managed Channel:0 Access Point: Not-Associated
Bit Rate:0 kb/s Tx-Power=20 dBm Sensitivity=8/0
Retry limit:7 RTS thrff Fragment thrff
Power Managementff
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
eth0 no wireless extensions.
Did you read the link I posted? It would work in ubuntu (or any other debian derivative)
Thanks bro there is no need i have solved the problem and everything is running great including Flash Player, don't ask me how i done it ,all i know i have downloaded restricted pakages from Ubuntu and went in the update software ticked some items the reloaded unloaded, my finguers hurt of some much tempering with it,the only thing i know i'm an happy camper
i'm happy that tried so many distros and ended up with the better( for me of course) an easier and windows very alike for even easier to navigate.
thanks for trying to help appreciate.
