Hi guys I want to make my system quieter, so i decided to get some new fans.The case is NZXT Tempest 410 and i need 6 new fans since i cant put a second one on the side because my videocard is too big
.I looked around for fans and chose two, which i think are the best. They are the following:
Noiseblocker BlackSilentFan XL2-1500rpm
Bitfenix spectre white led-500-1000rpm
I am going to use them with a fan controller which i think will make them both quieter on low power but I am still not sure. I want something that will have a balance between noise and air pushed. Another thing I am not sure about is if there is a better fan on that budget.
Thanks in advance!
Thanks in advance!
