1) I didn't follow the guide for SSDs stickied at the top of the section. Should I reinstall and start from there? (I simply installed everything as if it were a normal, non-SSD storage device). I've been using the computer for around a month or so now.
2) My reported amount of space used seems to be different from the space used that shows up when I select all of the objects within the drive and check their size as a group (Hidden files and folders are set to "show"):
Is there a reason for that?
EDIT:
System specs
OS: Windows 7 Professional 64-bit
RAM: 16 GB
CPU: i5-4670k
GPU: 7970 HD
HDD/SSD: 128 GB boot drive, multiple HDDs (individual, not RAID)
EDIT:
System specs
RAM: 16 GB
CPU: i5-4670k
GPU: 7970 HD
