Need help on aple pcc ubuntu install!
ivtec
banned
Hi Guys: i finally i made an Iso of Ubuntu 12.04
http://cdimage.ubuntu.com/releases/12.04/release/
on a cd and booted up wih it everything went great dowloaded the full Ubuntu install then asked me to reboot but it wont boot up and give me this on black black sreen and got stuck there don't go anyware,need help here or this aple will be landfill,thanks in advance.
Ubuntu 12.04
[23.636191] b43-ph0 error:Firmware file"b43-open/ucodes.fw" not found
[23.635732] b43.635-phy0 error:firmware file "b43/ucodes. fw" not found
[23.636656] b43-phy0 error: you must go to http://wireless.kernel.org/en/users/...devicefirmware and download the correct firmware for this driver version
Thanks Cromewell, i don't see that upon installation i fallow some instraction from this link,
https://help.ubuntu.com/12.04/installation-guide/powerpc/howto-installation.html
this seems to be a diferent from ubuntu 12.04 for win or linux i think what's broke is the yboot ,i can get in the boot terminal not the linux terminal,i can type command but none is valid, i can't go anywhere from here no keyboard accion just freezes there i can reentall from the cd as i tried a few times new istall, i install the auto install ,i can install manually but i don't know what to install, it presents me with all the software to be installed
if you know any tips please help, like this this pc is land fill cause i had deleted tha aple partion so can't go back to mac ops,.
When you put the disk in the CD drive and try to boot from it, do you get the option to run it as a livecd? or does the installer just start?
The steps I linked depend on being able to boot it as a livecd.
If you can disable the wireless (what I've found seems to suggest that this is the issue) you may be able to install it without doing anything else.
One way or another you should be able to install Ubuntu on it. It may take a few tries though. It seems ridiculous to me that this would block the Ubuntu installer.
When i put in the cd i press c on the keyboard and starts the install right a way asks me if is New York regian then asks to put name and password,asks me to put some key for the keyboard or leave default,then at some time presents me with the partions i want, i choose one partion full hhd then i also can choose manually chosen install software it presents me all the software that is gona be installed i choose auto ,but this is similar to ubuntu 12.04 but with diferent conf.
I literally had this exact same problem once trying to install Lubuntu on a PowerMac G4, but I can't for the life of me remember how I fixed it. :mad: If it gives you hope, I do know for sure that I did eventually get it working. :)
Well spynoodle if you do remember that would be a great help thanks for the effort.
There's a link on
https://help.ubuntu.com/community/Lubuntu/GetLubuntu
for media specific for mac's
Thanks NyxCharon; i downloaded the Lubuntu 64bt pcc and it installed as easy as Ubuntu but it improved but i get stuck at terminal i can login by pressing ctr alt f1 combination ask name and password i can get in the terminal i could do sudo apt-get upgrade and it updated all but still can't get to desktop,
i think this is a graffic card problem maybe! lack of drivers.now i'm better with Lubuntu cause have control, now what comands should i do to bring desktop back or get the right i think this is Nvia drivers not sure!thanks in advance.
Yeah, if I remember right, I think it was a graphics driver issue. Do you have any spare PCI or AGP cards that you could try to boot with?
Thanks spynoodle: i have an ati card on an compact presario but how do i swapp it since this is a diferente all in one aple desktop only has the Display and inside the display is everything don't know if it has a slot for a card or the card is part of the mother board
bellow link are the specification of it i think.
http://support.apple.com/kb/sp96
Do you have an iMac, or a PowerMac? I'm unsure if the iMacs have swappable graphics cards, but the PowerMacs should have an AGP slot, which you could possibly swap another card into.
Sorry but this is the wrong specs, bellow link on e-bay there is one just like mine.
ebay.com/itm/aple-iMac-20-Desktop-M9845LL-A-May-2005-/261259858957
20" APPLE IMAC G5 A1076 1.8GHZ 1.25GB 180GB WIFI DVD BLUETOOTH OSX
Seller refurbished
$209.00Buy it now
29d 1h 49m
this is the one for sure
Apple iMac G5 Desktop 20" M9845LL/A (2.0 GHz 512 MB RAM, 250 GB PowerMac8
Sorry I can't read what it says on the screen but it looks like you've gotten to the command line and it's otherwise working. If you were expecting a GUI, perhaps you installed a lighter version than you meant to?
Try typing startx when you get to the command prompt. If you get an error message like "command not found" try sudo apt-get install ubuntu-desktop and then try startx again.
This is definitely something similar to what happened to me, and something that I've also seen happen even on x86 Linux installations. Have you tried any of the suggestions on this page?
Btw, nice piano playing. :)
Thanks, i do what can, i learned music and how to play by myself,
about the ubuntu installation i'll give it a try on that link,thanks.
Hi guys: sorry to bring this up again,but i checked the ubuntu website and checked requirement to install ubuntu and it says 1GB MEMORY RAM,so i thought this might be my problem since i only have 512bt memo there is a slot to install one set of memory.
Any advice on that thanks in advance
