DMGrier
It was $200 off all MacBook Pro's when I looked a few days ago.
I think you guys are living in the past, you can't get a comparable Windows laptop for half the price of a Mac.
13" MacBook Pro
2.9GHz Dual-Core i7
8GB DDR3-1600
750GB 5400RPM HD
Intel HD 4000
7 Hour Battery Life
$1,299
14" Sony VAIO Fit
2.0GHz Dual-Core i7
8GB DDR3-1600
750GB 5400RPM HD
Intel HD 4000
4 Hour Battery Life
$999 (Not really much cheaper considering for $300 more you get a 2.9Ghz vs a 2.0GHz CPU, and almost double the battery)
15" HP Spectre XT
1.9GHz Dual-Core i7
8GB DDR3-1600
500GB 5400RPM HD
Intel HD 4000
3h 45m Battery Life
$1,299
14" Dell XPS
2.0GHz Dual-Core i7
8GB DDR3-1600
500GB 5400RPM HD + 32GB SSD
nVidia GT630M
Unknown Battery
$1,199
As you can see, comparable laptops are very similar in prices to Mac's these days. People are stuck in the past where maybe 5 years ago Mac's were twice the price. Sure, you can get budget laptops for $499, but the specs are much worse, build quality is laughable, and they are bulky and heavy.
No one is living in the past, if you do not care about the aluminum body and Retina display a PC is easily half. My laptop is three years old and is still running like the day I bought it and my computer has easily seen more travel then almost anyone else on this forum excluding other military personnel.
As far as your Macbook Air comparison, it doesn't work since the Macbook Air just got updated and many models you listed have not seen updates. Lets jump back 3 months when a top of the line Macbook Air ($1,499) which is the same price as a top of the line Dell XPS (1,499) but yet the Dell had a i7 and a much higher resolution screen.
Edit: I am sorry I saw your comparing the Macbook Pro to the Hp Spectre, that is why I said Macbook Air cause the spectre is a ultra book so I assumed you meant Macbook Air.
On a further note Apple can only be some what competitive in hardware when they first release the models, when looking at the models a month or two before the next release they are really expensive. A good example is a base line Macbook Pro at $1,200 with a i5, 4 GB RAM and a 5400rpm 500 GB HDD. You know Apple is making a killing on those. Or who remembers how the last two years of the original Macbook's saw very minor updates yet where still being charged $999. Either Apple is taking pure advantage of the customer base or whoever is in charge of the buying department needs to be fired.
