S.T.A.R.S.
banned
Well folks...
The title says it all...
Give us your complete computer specifications and let's see who has the weakest computer on this forum!
NOTE: Do not give us the specifications of the computer(s) which you used in the past or the ones you have but do not use anymore.Give us the specifications only of the computers which you are using right now!
Well...let me start with mine almost 15 years old computer so well known to everyone already
Motherboard: KT400-8235 (it's in beautiful red color lol).
Processor: AMD athlon XP 1700+ 1.4 ghz socket 462 (A).
RAM memory: 512 MB of RAM DDR1.
GPU memory: Nvidia FX5200 64 MB of VRAM.
Hard disk drive: SATA - Seagate 320 GB 7200 RPM (upgraded from PATA/IDE - Seagate 40 GB 4200 RPM) and therefore the PATA to SATA converter has been used on the motherboard.
Keyboard: Compaq PS/2.
Mouse: Genius PS/2.
Number of USB ports on the motherboard: 2.
Number of the USB ports which can be added to the motherboard: 2 (I have added them).
USB port version: 1.1.
Speakers: Hama green pin.
Number of fans inside of the computer's case: 6 (this includes the fan(s) in the PSU (power supply unit) and GPUs as well).
Don't know the name of the fans since the label has been taken off them LONG time ago lol.More than 13 years ago lmao!
But I am planning to change them since they became loud as hell lol!
I will probably go with Sharkoon since they are cheapest here.If I am not able to find them then I will go with Cooler master.
Power supply unit: MaxPower 115 watts (but planning to upgrade it to a 420 watts power supply which I have new packaged in the box lol).
CD/DVD-ROM drive: PATA/IDE - Super write master light scribe speed plus.Capable of burning CD disks,DVD disks and dual layer DVD disks.
Number of fans used to cool the hard disk drive: Unnamed 2 80mm blue led fans and 4 40mm fans.
USB hubs (if any): 3 (10 ports per USB hub).
Leds: Green POWER led,red HDD led.
Switches: Power ON switch and RESET switch.
Motherboard speakers: Only 1 simple system speaker connected to motherboard pins.
Monitor: Fujitsu Siemens - VGA (can't remember how many inches it has right now).But it's the thin monitor thank God lol.It was a replacement of the big fat unnamed box monitor lol.
Case: Very small white case from 1995.
And finally the operating system and the month and year when it was last installed or reinstalled: Microsoft Windows XP professional edition with the service pack 1,2 and 3 (no other OS updates have been or will be installed).
Last month and year of installation: 07.2004. (Can't remember the day lol).
Well people that was mine.Hopefully there will be someone with worse computer than mine!
So go ahead and GIVE US the specifications of your weakest computer which you still use even today and let's see who will be the winner!
Cheers!
Mouse: Genius PS/2.
Cheers!
