Gigabyte GA 970A DS3 rev 1.0
Look in the back of your PC where your video cable is plugged in. See if you have another video port exactly like it. Most motherboards have a built in video port and you may have a video card in the slot.
The built in port is vertical and the card is horizontal.
This has worked for the moment! Thank you. I will attempt to install the audio drivers and get them working tomorrow. Should this not work then I will report back on here.![]()
Dont really know how that worked, his board does not have onboard video. I suppose he just used another port on the video cad.
