question about ethernet card driver
You just said your new router doesn't show up in the list. Unplug your old router and remove it from the equation. If its unplugged and turned off it won't show up in the wireless networks. The posts you have been making are confusing... Can you better explain? Are you connecting to the new router or not?
no,what I'm trying to say is that,I can't connect to the internet on my new router.
no,the security key is allready in there,I click on the connection it says it's connected,but it's really not,where the internet is I see that and there's a red x there,it also says local only,for where it's supposed to be local and internet,it will say local only.
read this
Are you sure the key was put in correctly? You're best bet is to delete the existing wireless profile and re-connect, entering the wireless key precisely (they're case sensitive).
