SSD Used/Unused capacity
A_Tom
I have a 60gb drive which shows to have only 22gb of unused capacity. If I add up the size of all of the folders under this drive, I get about 25gb, which should leave 35gb unused, more or less. How can I figure out what is using the extra capacity and is there some way I can free it up? I've emptied the recycle bin.
Download and run WinDirStat to see what is taking up space on the drive. Also keep in mind the way NTFS behaves you won't see a full 60GB drive - more along the lines of 55GB or so.
https://windirstat.info/
I suppose that windows explorer disk usage does not reflect hidden files, so I suppose not. I'll do more checking.
Taking into account the file size difference when formatting the drive, you only have ~8GB unaccounted for.
Did that, thanks. It's mostly in 2 files: pagefiles and what I take to be a hibernate file. The pagefile space is obviously necessary, but I'm not sure about the hibernate, since I never use that.
Did this: (from cmd window) powercfg.exe -h off
This gave me about 6 more gb of disk space.
How much ram does your system have? I'd change your pagefile size to a custom size of 2048mb if you have more than 4GB of RAM installed.
1) Reduce page file size. Set it to a static size through system properties.
2) Run this from elevated command prompt to disable hibernation and delete the hibernation file: "powercfg -h off" (without quotes)
3) If you have MS Office installed and you have the installation media, you can safely delete the MSOCache folder under the C drive
4) If you've installed AMD of Nvidia drivers, check the C:\ folder for AMD/Nvidia folders and delete them as they only contain installers. For nvidia also check in program files for the "installer2" folder under nvidia which you can also delete
I got rid of the hiberfile. Since I have 8gb of ram, the page file is set to 8 also, which is fine with me.
You don't need or want an 8GB page file with an SSD. Shrink it down to 1 or 2GB.
