Nothing really. It's fine with the service packs.
Poor driver support upon release is what hurt it...
True, but you have to remember that at the time they were actually average kind of specs. When Vista came out, 2GB of RAM was quite a lot and multi-core processors were still expensive, so of course people bought weaker machines and obviously Vista ran slowly because a) it was demanding (for its time) and b) OEMs tended to install a lot of bloat which most people never removed.OEM's were shipping PC's with crappy specs and Vista installed so a lot of people complained a lot about that.
^true but I still think that a lot of the negative came from people buying systems that were build for XP and running Vista. My first laptop was a Vista PC with 512mb of RAM. it was terrible. I used Vista full time again in my internship. On better hardware with the updates installed it is way better.
...who cares what people say if they are uneducated...
I don't get it, I'm running Vista now, and I'll continue using it when my 8350 arrrives
Any arguments?Vista sucks.![]()
Yeah, if you install 7 or 8 in your old vista PC that sucks it will be the same.
I have 4GB RAM too (might upgrade to 8). My FX 8350 will arrive on April 9 and Vista runs very good on the E8400, just like 7 ran.
Any arguments?![]()
Hi spirit,I run Vista on an old Toshiba Saellite 355 and it's preety slow booting, can you please tell me what OEM solftware should i remove without disrupting system,i do Defragment and clean frequently, Thanks.
Nonsense. Windows 7 and WIndow 8 will run much much better on lower end hardware than Vista. FACT!
Thats BS. My D610 ran much better on Vista then W7. Don't know about W8, but I doubt that it's any less resource intensive than 7. Boot was much faster, programs launched faster. Hell, even the Start menu opened faster than 7. On modern lower end hardware (C2D, LGA115x Pentium dual) Windows 7 will run better then Vistsa, I agree. But you shouldn't group up "low end hardware" like that, as it can include a 2003 D610 or a Pentium G3420 which is basically a i3 without HT IIRC.
Calin, I don't think Vista is bad, but nowadays it's quite dated. I recommend upgrading when Windows 9 comes out.
http://www.tomshardware.com/reviews/windows-7-performance,2476-10.html...the most noticeable differences show up when you compare Windows 7 and Windows Vista doing everyday operating system operations. Startup, standby, and hibernation are much faster, proving that Microsoft had to turn many things upside down to reach these performance benefits. Given the fact that Windows 7 is more aggressive when it comes to performance versus power saving, considering the tangible performance benefits, and having felt the improved experience when handling Windows 7, our conclusion is rather strong this time: should you want to improve your Windows-based system, now is the time to change up to the next-generation edition—provided that you find driver support for all of your components, which may be particularly tricky for some notebooks.
Our conclusion is not only valid for fast PCs but also for all systems that aren’t top of the line anymore. We’ve installed Windows 7 onto many different systems and found that the new OS is even more favorable if your system hardware isn’t particularly fast. For instance, we noticed significant differences between Windows Vista and Windows 7 on Atom-based netbooks. Windows 7 showed much less stuttering than Windows XP and Vista. Just make sure you have enough RAM for Windows 7, as insufficient memory will slow down any system on every OS.
There's a lot to like in Windows 7, and that includes better CPU performance.
http://www.pcstats.com/articleview.cfm?articleid=2507&page=5Windows 7 makes a significant improvement over Windows Vista in these scenarios, with large performance gains demonstrated for nearly every class of processor.
Windows 7, unlike every previous version of Windows, didn't have increased hardware requirements to run smoothly. And on the same hardware, it runs significantly faster than Vista.
http://windows.about.com/od/windowsosversions/a/Win7vsVista_2.htmWindows 7 is much more stable out of the starting gate than was Vista.
