Advice on my first build
Just to clarify.
The only thing I recommend is a better PSU, future-proofing and I think that's a little weak for your build.
This.
If you can afford it, or rather you WANT to afford it.
Otherwise something like:
This.
This.
This.
Or this. (cheapest)
Just to clarify, its absolutely not a good idea to put a 1200W psu or greater in a machine and then run it a 20% load as it will be very inefficient and is simply a bad idea economically and technically.
Don't worry, I find this bickering cute...I don't see how it would be inefficient, but I simply don't know enough about power supplies to call you on that.
