TheRealBidi
Hello, I was just wondering if these specs fit in the case and are compatible with each other, I'm about 80% sure these are compatible for each other but I haven't a clue if they fit in the case and I don't know how to check that
Case: BitFenix Comrade Midi-Tower
Hard-Drive: 1TB Seagate Barracuda ST1000DM003 3.5" SATA III
SSD: 250GB Samsung 840 EVO Series 2.5" SATA 6GB/s (SATA-III)
Disk Drive: Samsung 224DB 24x DVD Re-Writer - SATA - Black - OEM
CPU: Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150
Fans: Cooler Master Hyper 212 EVO Quiet CPU Cooler
Memory: 8GB (2x4GB) Crucial Ballistix Sport 1600MHz CL9 DDR3
Graphics Card: Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 Graphics Card
Motherboard: Gigabyte GA-970A-UD3P AMD Socket AM3+ Motherboard
Power: EVGA 500W 80 Plus Power Supply
(!!Also would a need a wireless adapter, because I'm planning on using wireless, or do the motherboards already have wireless in them?!! !!And does the intel i7 already come with a fan or do I have to buy one seperate?!!)
If one of you could check if it fits in the case and are compatible with each other that would be great!
Thanks in advance.
Thanks in advance.
