Need Help With BUilding A Computer
TheRealBidi
Hello, I was just wondering if these specs fit in the case and are compatible with each other, I'm about 80% sure these are compatible for each other but I haven't a clue if they fit in the case and I don't know how to check that
Case: BitFenix Comrade Midi-Tower
Hard-Drive: 1TB Seagate Barracuda ST1000DM003 3.5" SATA III
SSD: 250GB Samsung 840 EVO Series 2.5" SATA 6GB/s (SATA-III)
Disk Drive: Samsung 224DB 24x DVD Re-Writer - SATA - Black - OEM
CPU: Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150
Fans: Cooler Master Hyper 212 EVO Quiet CPU Cooler
Memory: 8GB (2x4GB) Crucial Ballistix Sport 1600MHz CL9 DDR3
Graphics Card: Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 Graphics Card
Motherboard: Gigabyte GA-970A-UD3P AMD Socket AM3+ Motherboard
Power: EVGA 500W 80 Plus Power Supply
(!!Also would a need a wireless adapter, because I'm planning on using wireless, or do the motherboards already have wireless in them?!! !!And does the intel i7 already come with a fan or do I have to buy one seperate?!!)
If one of you could check if it fits in the case and are compatible with each other that would be great!
Thanks in advance. :)
You have an AMD board and an Intel CPU there... not gonna work! You need to get a Z97 motherboard. Look at the Gigabyte GA-Z97X-UD3H.
Get an i7 4790K. It's newer. And yes it comes with a cooler.
Also get a bigger PSU - look at the Corsair CX600M.
Other than that, all good. :)
You might also want to take a look at the GTX 980 its faster, better, and cheaper than the 780Ti. However, there's no custom coolers out right now, so you'll have to wait a bit.
