Hi guys, i desperately need your help. I've been trying to fix this problem for a while now and none of the popular methods that i found online have fixed it. After i keep my pc off overnight lets say, i turn it on and right after i log on the display driver crashes about 8 or 9 times and then bluescreens caused by "atikmpag.sys" after that the PC will reboot and upon next startup may crash once or twice but is then absolutely fine for the rest of the time im using my pc. It never happens other than at those times upon startup and but the strange thing is that after it has crashed etc on the first 2 startups, i can reboot my pc as much as i want with no display driver crashes whatsoever. Please Help!!
I have tried:
Reinstalling the driver software several times.
Installing later drivers (14.9 i've tried)
I've tried reinstalling windows 7 and installing windows 8 instead
manual expanding the atikmpag.sys and atikmdag.sys files
adding a TdrDelay in the registry (manually and by using the hotfix)
Another thing, and im not sure it's important but on startup the windows logo staggers.
Any help is greatly appreciated, i've had this problem for months.
Specs are:
CPU - AMD FX9370
MOBO - M5a99FX Pro R 2.0
RAM - ADATA XPG V2 8GB DDR3
GPU - 2GB XFX 6870 + 1GB XFX 6870
PSU - Coolermaster GX 750w
I have tried:
Specs are:
CPU - AMD FX9370
