PLZ READ! - Processor heating issue
Hey guys!
i am not new here, but i am (in a way!)
Many of you know me and helped me some time back with my graphics card and PSU upgrade. Fans too..
FLASHBACK:
http://www.computerforum.com/230833-graphic-card-needed-12.html
Am here to share what problem i am facing with my PC now and need your help..
I have noticed that since my GPU and PSU upgrade, the CPU temps. have gone drastically high and they tend to remain that way even when under very little load (gaming- farcry 3, sniper elite 3). I know i shared this earlier too but now the problem is so much that the PC refuses to start every now and then. Even if it does start, it restarts after every, say 20-30 mins.
While gaming the CPU temps go upto 80 degrees C whereas the GPU temps remain b/w 60-65 C max.
Even while not playing any games, just surfing the net, it restarts and often after the restart it refuses to load i.e. keeps on restarting again and again(loop).
I have 3 fans as of now. One 12" exhaust, 1x 8"sucking cool air inside the cabin, 1x 8" fan located exactly parallel to CPU fan- throwing air outside.
I recently changed the thermal paste too, but don't think it helped (it was some cheap thermal paste.)- used this because only this was available in the local market.
I upgraded the RAM too some 3-4 months back which, by mistake, i purchased of wrong speed. The MOBO supports upto 1333Mhz whereas i purchased 1600Mhz Ram. Right now there are 2 sticks of RAM that are being used 1x 2GB- 1333Mhz and other 4GB- 1600Mhz. Can this be a problem leading to restarts??
IF YES, THEN WHY DOES THE CPU TEMP. GO UP TO 80C ????
My PC is 4yrs. old Intel I3 + INTEL MOBO {DH 55 TC9(B)}+ CX 600+ RADEON R9 270+ 1TB WD (GREEN- PROBABLY)+ 2GB KINGSTON 1333MHZ + 4GB KINGSTON 1600MHZ+ 22" LG LED
IS THERE ANY WAY THAT I CAN MAKE THIS CONFIG. WORK? OR DO I NEED TO CHANGE THE CPU N MOBO?
Hey guys!
FLASHBACK:
