This. 750 TI would be my vote.
Thank you for your vote , it makes me even more comfortable in this big decision I need to make , more votes the better ! =D
Also, the Windows 10 tech preview is free, so you may want to use that
You should stop doing this. It should not be a go to to recommend an unfinished OS. If there's one piece of software you don't want unstable, it's your OS.
Half my games dont work with this stupid update.
Both games got updates right before tehy stopped so maybe thats the issue
But I'm in another state for a long time and don't want to risk shipping it .
Something like this would be OK http://www.newegg.com/Product/Product.aspx?Item=N82E16813128694 $58
It just has a slightly lower-end chipset that's all.
Isn't this board incompatible with my Intel procesor ? I don't know much but it looks like it to me , sorry if I'm mistaken .
Intel Pentium G3258 3.2GHz Dual-Core Processor.Thought you were going AMD?
Which CPU are you using?
I'm following Cisco's build . But I'm using a 750 ti , for my gpu.
