How much paste are you applying? Is the cooler fitted with fans and all working. If it has 2 are they in push pull?
I used the dot method for nt-h1 and the vertical line method for the arctic silver 5. I cannot use the recommended push-push configuration for the nh-d15 due to compatibility problems with my ram, but I later reversed the fans to a pull-pull configuration (not sure how this would affect the performance), and the airflow remained the same.
Another problem that I have noticed is that using Prime95 would result in far more BSODs and overheating. 4.5ghz (1.18v) with occt was at least 10 degrees cooler than with prime95.
I've redone a test at 4.7ghz, 1.27v (for 5 minutes)
And here is the temperature graph: (use the link)
https://drive.google.com/file/d/0B4-X8UpTtPy7UFhuNjA0NmZUaUE/view?usp=sharing
As you can see, the temperature spikes shoot up to 97c, but it generally stays below 85c, is it healthy for the cpu?
This is a different graph resulted from a test at 4.7 ghz, 1.26v (This frequency is Prime95 unstable, but "everything else" stable)
https://drive.google.com/file/d/0B4-X8UpTtPy7QXd2ejJ0QnNEbFk/view?usp=sharing
But as you can see, temperature at this voltage is a lot more consistent, and I cannot understand how this is happening.
Third 4.7ghz stress test result, 1.26v, time span 10 minutes (to prevent inconsistency in results). Highest spike 95c, but generally stays well below 85c. Graph:
https://drive.google.com/file/d/0B4-X8UpTtPy7N2hpc2hIRjV4em8/view?usp=sharing
