Not a very high budget, but I found the Galaxy Tab 3 on Amazon for $120.
Just found this:
HP 10 plus
http://www.rueducommerce.fr/Ordinat...ifi-Gris-metallise.htm#moid:MO-D5EFFM54864624
I'm not willing to spend higher than this but I guess if I have too I probably will...
With a 1920 x 1200 display and Quad Core ARM Cortex, that's a really good tablet for 179 Euros.
I thought so, also are Windows tablet good?
Ok well, I'm still undecided between these two:
HP 10 plus:
Lenovo Miix 3 1030:
http://www.rueducommerce.fr/Ordinat...s-dans-la-tablette.htm#moid:MO-B2F3EM35199540
I get 50 euros back from Lenovo so it goes down to 150 euros. The plus side is that I'll have a keyboard and the downside is (well not really a downside) I have no idea if Windows tablet are good and have a good variety of apps...
Just make sure you buy a tablet that is not Windows RT. Looking at the one Punk mentioned, it's a full fledged Windows 8.1 install.With Windows 8.1 on a tablet you can basically install all software titles that will install on a Windows desktop. Most desktop titles don't work well on small touch screen displays though.
You gave him one model to look into. You didn't include the "guidelines" that you use when searching, so how could your post answer any of his questions or concerns?Hi, I am currently using an Asus Fonepad 7 tablet. I find it very convenient and handy to use especially when I'm away from home. However, if you still need more choices, I also search some guidelines for the best ones that would likely fit your budget. Take your time to read this. I hope, it can help answer all your inquiries.
The hyperlink is the same color as the text so I didn't see it.He did post an online article about what to look into when picking a tablet...
And to be honest, I find the question too vague to get an answer...
And you know you're the op right? If the question was too vague, you probably should have worded it better.
