CloneZilla copy screw up
Jsy
I used CloneZilla to clone a dell machine running Windows 7 because the other dell system (different motherboard) wasn't taking my Windows 7 discs/USB drive. The clone operating system took and worked great, but the Windows 7 updates didn't install the correct drivers, SFC /Scannow fails, and using IE to login to the DVR works fails. SO basically screwed up image.
Will a Windows 7 repair disc and updating the Dell driver list fix this? I know CloneZilla copies the existing registry and putting it on a new computer can mess things up, so is there a recommended fix without reinstalling Windows 7?
You can't do that. You can't switch an OS from one motherboard to a different one.
If you want to do that, you should install it on the one machine and then run sysprep and shutdown, then clone it.
