Check what standby setting is enabled in the BIOS. Put it in S3 if possible.
It's not completely shut down. It's sleeping.When I put it in S3 the computer turns off completely (Like Hibernate) and when I turn it back on by power button it resumes to the last window. I want it to go to sleep and not shut down completely. (Btw, I only had S1 and S3)
Everything went fine for only one day. Now even after putting my computer to sleep (which shuts down the computer) it turns back on immediately!! I want my "Stand-by mode" when the red LED used to turn off and only the green LED blinked waiting for me to press enter to wake up from sleep what should I do?
Disable wake up and power on by ring. You also need to change ac back function setting to stay off.
If I reset my cmos settings back to defaults will the following window change? I mean my SATA ports settings. I don't want them to change. You know I just had my Bluray Drive recognised by my computer. I don't want to lose it againIt needs to stay in S3 mode. Have you tried resetting cmos back to defaults? Also, check your power options in control panel for sleep mode.
