New Gaming Desktop on a budget
Get this with Windows 10, a 4GB GTX 960 and maybe the Fractal Design Define R5 (if it's not too much more).
Lose the CPU cooler and get a Corsair CX600M instead of the 750W PSU if you need to save money to afford the 4GB graphics card or anything else. You don't need the cooler unless you're going to overclock. In the Fractal cases the CPU will be fine at stock speeds with the stock cooler. 600W will be fine for one 960, in fact a CX500M would do it with no problems and save you money.
this list Scarified GPU, but meet your overall budget requirement & spec
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($247.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.75 @ OutletPC)
Motherboard: Gigabyte GA-Z170X-Gaming 3 ATX LGA1151 Motherboard ($131.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory ($39.99 @ Newegg)
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive ($89.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card ($159.99 @ NCIX US)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($69.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($44.99 @ NCIX US)
Optical Drive: LG GH24NSC0B DVD/CD Writer ($13.99 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($89.95 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($18.89 @ OutletPC)
Total: $979.40
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-03-03 09:21 EST-0500
That 750W EVGA only $45 after MIR, that's why choosing it. I don't think Corsair CX any better.
You could consider cheap CX500M if not upgrade higher end GPU in future.
You can't lose the cooler as i5-6600K don't come with one.
Does it not come with one anymore? If so I didn't know that, thanks for letting me know.
The CX might be cheaper even without rebates.
What that board can take is a Samsung 950 Pro M.2 (technically 2 if you wanted, and most likely a RAID option too! ) Referring to the Gigabyte board!!
ok so im ready to order the parts. if i buy em all from all thelowest priced places it will cost me $900.00 if i buy from newegg $996. which is horrible are all those other sites legit? just use to dealing with newegg
If you are still only getting the gtx960, you don't need that much wattage. Just get the 500 watt evga unit. To me its a pain buying from multiple places especially if you have to rma parts because they don't work.
