Thank you, any other suggestion?
I'm starting to think than having 16Gb ram and i7 will not make a laptop run fast and furious.
Makes up for the dual core CPU
Jerry, when my father got his new laptop, an MSI but same CPU and RAM as your Toshiba, he opted to ditch the 1TB drive in it, (which wasn't even 7200rpm) for a 250GB Samsung 850P Pro SSD and the difference was remarkable.
If you can sacrifice a larger capacity HDD, for a smaller capacity, but significantly faster SSD, you will most likely get the kick you are wanting.
Thank you again for your help, I'm searching for types of SSD to get one to fit my laptop.
This means I don't own a good laptop, do I?
Don't think like that, there are many options for many users. Nothing wrong with the 6500U its just not a quad core, and most people only associate i7 series as quad cores.
Your 6500U is a 6th generation CPU. 2 Cores/4 Threads
Oh, too bad. Now I know what's the problem with this laptop. I thought it was a good one lol.
It's a fine laptop, Jerry. It is possible its just not doing what you expected. An SSD will be a good help to you and I think it's worth the investment, if you do grab one post back and someone here can help walk you thru how to install it, copy stuff over etc!!
Don't get down about it, cause I've used my fathers a few times, and its a snappy little unit--I see no reason you wont achieve the same boost with minimal additional investment,.
Awesome, I'm going to buy the one you suggested me, can I keep both drives (HD and SSD) or should I replace it?
Jerry a caddy like this one from vantec http://www.newegg.com/Product/Product.aspx?Item=N82E16817392087&cm_re=vantec-_-17-392-087-_-Product would be a great solution to reuse the HDD when you remove it.
Nice I already got one. Thank youThe Samsung SSD will come with a cd that has software that will migrate your current OS to the new drive. You would have use a usb hard drive adapter such as this.
http://www.amazon.com/Vantec-IDE-SA...qid=1457744072&sr=8-8&keywords=vantec+usb+3.0
