postman,
Hey bro, what's up?
its really nice to see you.
i just had an epifany. if everyone in your nation and in the world had of all the virtues known to Man and did of good deed, then World War 3 will have been prevented. as you have started this process of good deed, this is a good sign for your help, as Rome fell because it expanded its territorial boundries too far, just like today, and european is part of this union, so the entire empire of Rome will to fall, including your country.
in the turn windows features on or off, what exactly am i looking for?
do you know of anything in this list that will help with this problem?
NOTE: i did not see anything that would help, unless the name has been changed or is unknown functionality.
postman
"youve probably disabled it using msconfig without knowing about the consequences."
i wanted to deliver this to you, for you to find the salvation of knowing the answer.
that's funny that you should mention that, because when you disable it, it "automatically" restarts the program, into eternity, as a soul unending to die, the program everlooping in time, again and again. ETERNAL LIFE is impossible in a world where your vote doesn't count, except on only local issues of no consequence, and where good deed and virtue is of no consequence. it reminds me of telling the governing body of parilament or thy nation not to do something and then for the corporations or governing body to do it anyways, but secretly.
postman
"run services.msc"
couldn't find an instance of this running. in what location should i look for a running instance of it, or an executable to so run it? you have earned 8 marks for this good idea, which would have worked under normal circumstances, other than the running of a problematic windows 10: run services.msc and msconfig.
postman
"make sure Windows Search is enabled and started."
what i meant, besides the meaning of life, the universe, and all of existance, was that was there a way to search for God besides looking at all of the material things of the Earth and that which we can hold in our hands? that besides using another program or Cortona, what i meant was there another way to search inside of the windows program? though i have to admit that everything is probably a better search, it does give administrative privelages to other users and so that they can see all of your files, not that Absolute Power wouldn't already be able to see 100% of your information with the windows 10 program. but i have installed everything that you see on Earth, and the program seems to work.
since "everything" here on this Earth is important, we should appreciate all of the things here and not take it for granted. could not find a way to run this file using this software program. everything that you could know in the Lord can help to save all of Mankind. you can make a difference, not in vote, but in thy FAITH of the Lord. this software program seemed to be useful. thanks postman, i will have to give you 7 marks for this one. quite commendable.
the problem is that if i
postman
then this will mean that cortona will activate and i will have given in to the "request" for them to have Absolute Power, which is 100% of my information, all across the world, and in this nation. in the future of Man this will lead to Absolute Power and the extinction of Man. so i do not want to enable cortona, as that is my choice in FREEWILL, where Absolute Power gives you NO choice and does so without your consent or agreement. i you enable cortona then you are allowing the corporations and governing body of thy nation in crown of empire and power to collect and use information including your location and location history, contacts, voice input, search history, calendar details, contact and communication history from messages and apps, and other information from any other devices; to use your browsing history. and you have to give up all of your rights and freedoms and privelages and Constitutional Rights just for you to be able to use the "search function" on your OWN COMPUTER!!!
the eye at the top of the pyramid does see all with money, but God also sees all. so we are treading on almost equal ground. nice program.
Problem #7: should have been more clear. windows 10 has prevented me from installing my printer, but the documents stated that if i updated the drivers, then i could fix this problem. however, if my printer is not installed, then i am unable to use the program or updated drivers.
i will give you five marks for that one just because it was a really good idea. maybe there is still some way to get around the windows 10 problem...
postman
"icon/symbol recognition. "
yes, the pyramid with an eye on it and the crown will prevent of all life in the world, and the Lord can make all the difference in the world; so yes, the icon symbols do matter, i agree. gold is worth something afterall. and some ideas or people are worth their weight in gold. never thought about this before. i never looked at the material things of the earth and the status that it brought with the icons shown next to the file with an extention file type associated with it, for i did not judge a file by the color of its skin or symbol, nor what it looked like in shape in size, for all people are equal in the eyes of the Lord. and God loves all of us equally.
postman
"i now i have retreated to my own shrine asking for increased divine energies"
of these things can come to you, the Divine Blessing of God.
postman
" hopefully i will be rewarded with a sign"
with of thy many virtues and good deed, of a New Age of Man to dawn upon the Earth, and the end no longer, but in the end, not to end,
{but only to'n bee'th the beginning instead. But of ye to'st of only'n have'th if'n of thy FAITH in'st of the Lord is 100% in total and'n of 100% certainty}
otherwise, with of shame, of money and power and authority of crown, to'st of thy world, and'n of the end of this windows 10 install to take place.
