TreeHobo7
Nice. But will VRAM work with Intel CPU and an AMD GPU?Then, the extra VRAM would be very useful.
Oh ok.VRAM just refers to video memory. Like when we talk about a 4GB card or 8GB card that is just the amount of video memory on a particular card.
Oh ok.
The case will probably be a corsair, any suggestions?
i5 6xxx chip with DDR4 RAM and a Z170 Socket 1151 board is what you want.
Corsair make good cases. If you want us to recommend a specific one then it depends on your budget and the style you like. It's hard to go wrong with Corsair, they're all good.
alright.Corsair, NZXT, Phanteks are all excellent case options.
You need tolook at a different CPU, that i5 is over 2 years old and 4th gen,, we are well into the 6th gen now..
I'd look at a Skylake build mobo/cpu cost a bit more, but better going forward in my eyes
I don't want to spend more than 70 bucks on a case.i5 6xxx chip with DDR4 RAM and a Z170 Socket 1151 board is what you want.
alright.
Ok. That is great! I have a laptop that will be my main media driver with a few indie games for on the go.If you dont require a DVD/BluRay drive, I'd look at the Phanteks P400, they were on sale at Newegg.ca just yesterday at $74
We live in the future lol.yeah, and there is nothing stopping you from purchasing a cheap external usb dvd player if you need it down the road.. My next build will definitely be a solid front, no need for drive bays anymore, pretty much no need for HDD either as I'll be going M.2 right on the motherboard
What's your total budget? Rather than giving piece meal suggestions on individual parts and not knowing how much you want to spend on a computer, you're probably better off giving a budget and then letting people here do their magic.
Then don't. Get a sub $70 Corsair one. 200R or 300R or one of their SPEC ones would be ideal.I don't want to spend more than 70 bucks on a case.
My NZXT H440 doesn't have any optical drive bays. I put my Blu-ray RW drive in an external USB enclosure. The enclosure cost more than the drive now costs to buy and has been no end of trouble. If you have it plugged in via eSATA movies are choppy in PowerDVD, if you have it plugged in via USB it won't burn any kind of disc (CD, DVD or Blu-ray). It's very annoying. If you buy a case that doesn't have the 5.25" bays I'd fall back on what you suggested and instead of getting an enclosure for an existing drive just buy a drive that's already external if you require an optical drive. I'm tempted to buy one eventually but it's not the top of my priorities given that I rarely use the drive or burn discs anymore.If you dont require a DVD/BluRay drive, I'd look at the Phanteks P400, they were on sale at Newegg.ca just yesterday at $74
I have a laptop with a disc drive just in case too.Then don't. Get a sub $70 Corsair one. 200R or 300R or one of their SPEC ones would be ideal.
You guys are great, thank gods for internet!He has a $1000 usd budget. I'm on Newegg.com right now making a sample build, do the same to give him ideas!
I trust Laquer Head will spec a good build for you. Let's see what he comes back with.You guys are great, thank gods for internet!
I trust Laquer Head will spec a good build for you. Let's see what he comes back with.![]()
