Why don't you want to keep windows 10? Is it the start menu? If so, download and install classic shell.
I can't even rename a folder without problems.Probably just need to backup your data and do a clean install. Most issues should be taken care of then.
What does it mean "a clean install"? I have Wind 8 in the motherboard of HP comp. I can only upgrade Win 8 to Win 10.Don't think a problem like that would be a compatibility problem between 10 and a HP computer. Would be the best to do like john35 said, a clean install.
I tried get new BIOS version from HP, but HP did not find it.Also make sure you have the latest bios, drivers etc for Win 10 from HP.
I thing the problem is HP computer configuration.Don't think a problem like that would be a compatibility problem between 10 and a HP computer. Would be the best to do like john35 said, a clean install.
How I do Wind 8 installing again.
I do it right now.Didn't you use the method I posted and revert back to windows 8?
I did Win 10 reinstall with saving of my files, but it does not help.Nope, haven't tried it as I have been running 10 for about 6 months now. It should work just fine. But again, you probably just need to backup your data and do a fresh install of 10 to get everything working correctly.
