my current setup :
Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
Manufacturer: Intel
Speed: 3.4 GHz
Category: Performance
Generation: 10th
Brand: Core i5 3rd Gen
Cores: 4
Name: AMD Radeon HD 7700 Series
Chipset: AMD Radeon HD 7700 Series
Manufacturer: ATI
Memory: 1024 MB
Generation: 14th
DirectX: 11.1
I want to update my graphics card, however I couldn't begin to understand how I can find which is the right fit. Does it work with my computer? Why does it cost so much? and etc... I use the http://www.systemrequirementslab.com site to see how my computer will work and my Dedicated Video RAM for my graphics card is always too low. I have 1gb currently. I show also on the site on which series are better then others, such as a Radeon R7 240 would be better, however they seem so cheap that I dont know what im really looking at. My current card isnt that expensive also. So im looking to see if I can get some help understanding what to look for, what fits in my computer and a card that is affordable ($100 maybe?). Again I dont know what is possible for pricing. Any help would be appreciated.
Manufacturer: Intel
Speed: 3.4 GHz
Generation: 10th
Cores: 4
Manufacturer: ATI
Memory: 1024 MB
Generation: 14th
DirectX: 11.1
