keep GTX 770 or upgrade?
Status
Not open for further replies.
lincsman
Hi there. I sold my computer but am still using a GTX 770 until I get a new card in my new computer. My question is, for the old computer... with 16GB DDR3 RAM and a AMD FX 6300 at 3.8Ghz, is the GTX 770 2GB basically the most the computer would make use of, or would it be worth my while and the customer's while to use a GTX 970 instead as an upgrade? Thanks.
Man, how many of these are you going to make? :P
If the 770 performs to their goals then roll with that. If it isn't sufficient then roll with a 970 (or alternatively 1050/1060). You have an advantage since you are related to the 'customer'.
Man, how many of these are you going to make? :p
3.5
OK I'm going to close this thread because you've made several threads about this. Let's keep the chat about this issue here in this thread: http://www.computerforum.com/threads/bottlenecking-reposted-properly.240759/
In future please don't make multiple threads about the same question or issue. We try to respond to posts as quickly as possible, but please be patient and somebody will reply. Feel free to bump a thread after a day or two if nobody replies (by posting a reply to your own thread), but please don't make new threads about the same issue.
Thanks.
Status
