computerpal
I basically want two wifi router/modems for the same dsl connection that i have because:
1. I dont want to go upstairs everytime to turn on the modem to use wifi downstairs
2. I would like to keep my upstairs modem seperate from the one i want below
3. If you suggest i get switches, will i be able to switch the modem on and off from downstairs below itself? &
4. If the answer to that is yes then isn't it easier to get another modem downstairs that i can turn on and off right from there? i mean if i had a second modem i think it would be more effective than a wireless wifi extender
any help at all is appreciated
