lincsman
Hi there. I was using the second PCI-Express slot on my motherboard and switched to the first one, which is x16. It failed a lot... games crashing or not even starting, with my GTX 770 2GB. So I put it in the second slot again, which my manual says is x8, and it works like a charm. So is it worth it to get the motherboard replaced to get the x16 working? Or would I even notice a difference? Thanks. I only plan in using one video card.
