The fan is connected to the motherboard in my case but I am not sure if the bios is able to control it.Case fan should be operating at all times, unless it is controlled by a PWM controller either from a separate pwm controller, or if the fan is connected to the mobo and the bios has the ability to control it.
okay, thank youIf it isn't spinning the bearing likely died and the fan needs to be replaced.
I understand, thank you for the tip !You can usually tell by manually spinning the fan either direction with your finger while it's off. If it doesn't "wiggle" as it comes to a stop then the bearing is bad. Spin a fan you know is good and watch it as it comes to a stop and you'll see what I mean. Hard to explain.
Most of us around here actually work in the IT field so we've probably got ya beat on how many bad bearings we've seen.If anyone knows about dying fan bearings, it's me. I've had 4 case fans burn bearings and get replaced over the years lol.
True, but for a residential PC owner I've had my fair share tooMost of us around here actually work in the IT field so we've probably got ya beat on how many bad bearings we've seen.
Thats cause they committed suicide due to the mass amounts of dust bunnies and assorted debris in your case...If anyone knows about dying fan bearings, it's me. I've had 4 case fans burn bearings and get replaced over the years lol.
