You listed two motherboards there.
Is this compatibile and are both mobos compatible with other parts?
He meant to. He wants to know which board he should get.
Thanks, I will probably wait a little bit to see how new ryzens will performe and save some money to increase budget.Oh true. Thanks.
Then both are but get the B250. You should also get a bigger storage. Better quality too. I would say 16Gb RAM but 8Gb is enough for now. More at your budget.
https://pcpartpicker.com/list/jZKwpb
You could get the 1050 Ti for $30 more. It´s worth the jump if you have the money. Although I don´t know how prices are in Croatia.
Is this ok?
Future upgrades: SSD 60GB for OS and some game
4GB DDR4 RAM or sell this 4GB DDR4 and buy one 8GB and having 1 free slot
As far as memory goes, get 8gb minimum so 2 x 4gb sticks.
Performance from dual channel though.I´d say 1x8Gb since it´s a mATX with only 2 slots.
So, 2x4GB is better than single 8GB?Performance from dual channel though.
It's not thhhaaaat different except for certain applications.Performance from dual channel though.
What do you want to use it for?
If he decided to upgrade later, it would be easier to sell 2 sticks instead of 1 because most people want dual channel.Yeah you are right but I imagined he may want to have 16B someday and would be a bit more problematic to do it if he had both slots populated with 4Gb sticks.
But John, who the hell in 2017 would want to buy two 4gb sticks...If he decided to upgrade later, it would be easier to sell 2 sticks instead of 1 because most people want dual channel.
The people that only bought 1 4gb stick and want to upgrade to 8gb perhaps? easier to sell matching sticks then an oddball stick right?But John, who the hell in 2017 would want to buy two 4gb sticks...
