Totally_Lost
I've run WiFi and LAN connections simultaneously on one machine before. I had always just assumed that, if the LAN cable was plugged in, it would be the default connection. Then, WiFi would just be a failover connection if the LAN connection failed, for whatever reason(s).
Tonight, I was checking the properties of each connection and noticed the connection, from time to time, switching from the LAN to the WiFi, and back. Is there a particular reason for this to happen?
Thanks.
Thanks.
