You don't really want to use that as a full time rig.I chose xp because that is the product key that I had on back of laptop, disc did not come with a product key.
Well currently it's an internet issue, not a browser issue since he can't even ping websites right now.You need a newer web browser. IE 6 doesn't connect to a lot of websites anymore.
Go into device manager and tell me what is listed under network controllers.
During one of these installs (I have done this twice with same discs to make sure I was doing it right) laptop updated itself to IE 8 and it still didn't work. I am unable to manually update because it won't let me go to website to download.You need a newer web browser. IE 6 doesn't connect to a lot of websites anymore.
That is weird, doesn't make sense. Something makes me think you have a bad windows install. Pinging a website is causing an error and it doesn't use IE to ping.I did connect an ethernet cable directly and it did not connect except to msn.com and weather links etc on homepage, not outlook or any other websites.
I want to copy disc, correct?
Do you have an ip address? What if you ping 8.8.8.8 instead?ping request could not find host
Try downloading this and installing it, its the pale moon browser. See if it will browse anywhere.
ftp://palemoon:[email protected]/26.x/26.5.0/palemoon-26.5.0.win32.installer.exe This is the last official release that worked with XP. Save it to a usb flash drive and then install it.
You could actually just run the file from cd, no need for copying but since ethernet cable didn't let you browse either then the problem lies somewhere else. Thats why I'm wanting you to install a different browser but not sure if it will work. If not, sounds like a bad windows install.
Doesn't look like you are actually getting an IP address. Run the ipconfig on the system that gets internet and tell me what the IPv4 address is or just post an image of your results which would actually be best.
or get a newer OS which has product key included, right?
