Can't install malwarebytes.
Killer
Hello there, I have downloaded malwarebytes, but I still can't install it. Every time, I try so, I get this message:
Setup was unable to create the directory
"C:\Users\ts2\AppData\Local\Temp\is-EKQ12.tmp".
Error 1392: The file or directory is corrupted and unreadable.
Please help me.
Killer
I'm not looking for a solution for pictures. This sites and others sites, talking about error 1392, seems to be talking about a problem with images and pictures.
johnb35
Administrator
Was it installed at one time? If it was, use revouninstaller to remove remnants from the old install.
johnb35
Administrator
Ok try this. Right click on the install file and click on run as administrator. Hopefully that will work. What operating system are you using? Also what security software are you using?
