farmerjohn1324
Android version 8.0.0 running on LG G6.
Little bubble popup ads for "Wish" and "Lyft" apps.
The only way you really get adware or "viruses" is from installed apps. Have you installed any apps recently? If so uninstall them one by one and see if they go away. I know there was a flashlight app that both my mom and boss had downloaded that would give them adds after ending a phone call or just randomly fill the screen with an ad. Pretty obnoxious. Uninstalled it and they disappeared.
Nailed it. I don't know why that app is so high up in the app store. Newer versions of Android have it built in anyway.Yes, it is the flashlight app.
True but there's a difference from banner ads on a loading screen versus full screen ads that cover up other apps when you're not even using the one that's showing the ads. I will say Apple does a better job of curating their app store than Google.Most of the "free" apps you download from Google Play on Android are only free because they display ads. Often you can pay $1 or so for the same app without ads.
Yes.It's just part of the program?
You can get so called AntiVirus for phones but in my experience it doesn't really do anything except suck background tasks. If you start getting obnoxious ads after installing an app, uninstall that app.
Side note, if you ever get a notice or warning your phone has viruses it's just a scam. Just back out of it or restart the phone. Usually see them as pop up ads on websites, even imgur was doing that on my S8+ lately.
Process of elimination most likely.Sometimes I can't tell what app it is.
I got rid of the Flashlight app and I still get ads.
Is there a way to locate the app?
I guess I've been fortunate then. I've owned 4-5 Android phones and 3-4 Android tablets and have never encountered full screen ads.True but there's a difference from banner ads on a loading screen versus full screen ads that cover up other apps when you're not even using the one that's showing the ads. I will say Apple does a better job of curating their app store than Google.
Me neither, I think it's become an issue more recently as I've seen it for now 3 people in the past month or so.I guess I've been fortunate then. I've owned 4-5 Android phones and 3-4 Android tablets and have never encountered full screen ads.
