Unless the program itself has the setting then no. A program will usually use as much memory as it takes to play correctly. If you don't have enough ram, then you need to upgrade. How much ram do you have?
Technically the leak will be there regardless of how much ram you have. What game is it? Are you sure there are no work-arounds?It's that this one game I try to play is known for crashing due to there being too much ram and causing a leak?
It's Eden Eternal. The game hasn't been updated since 2016.Technically the leak will be there regardless of how much ram you have. What game is it? Are you sure there are no work-arounds?
