need to know what graphics card i should upgrade to
didnotdid
i currently have this but i really need to upgrade and my budget pretty low at about a 150$ so i really cant afford much i would love a 1080 ti but no way i could afford that lol
Graphics Chipset - AMD Radeon R7 240
Intel_man
what is the rest of your system spec? Especially the PSU. Don't want to recommend something your current build won't handle without further purchases.
Other than that, with your price point, you may be able to find a deal on a 1050 ti. GPU prices are starting to come back down again, so keep a look out on one for sale and you might see them at the $150 range.
didnotdid
Radeon Software Version - 18.3.4
Radeon Software Edition - Adrenalin
Memory Size - 2048 MB
Memory Type - DDR3
Core Clock - 600 MHz
Windows Version - Windows 10 (64 bit)
System Memory - 8 GB
CPU Type - AMD FX(tm)-6300 Six-Core Processor
johnb35
Administrator
Memory Type - DDR3
We still need to know what the exact model of power supply you have.
johnb35
Administrator
The power supply is what delivers power to your computer. Similar to this one. You'll need to open the side of your case and look to see if there is a model number listed on it. Is it a store bought pc or custom built one?
didnotdid
I should state that the computer I’ve built was all ready started on when I received it I got it from a auction palet and added the
well here’s the thing I buy actuion pallets a lot and I got the computer out o one of those so idk
johnb35
Administrator
As I said, you'll need to open the case and look for a model number or have someone that knows about computers physically help you. Without knowing what power supply you have, we can't possibly recommend what video card to get.
didnotdid
I’ll check when I get off today
_Kyle_
Well-Known Member
For a brand new card look for 1050ti's. If you aren't scared of trying a second hand card you may be able to snatch a RX 480, RX 580, or GTX 1060 on Ebay or something.
The 1050ti is also pretty easy to install, just pop it in, no power connectors or nothing.
