EpicSurvivor
So I am done with my Motherboard, would love to get something new, I don't need anything fancy and budget is certainly limited to around $100. I honestly just want it for gaming....
These are my two choices below, which one would you guys pick out the two? also please point out any possible cons that you guys can see with them. Not going to Overclock anything crazy. Also not sure if its compatible with my current RAM? (Signature) and if it will fit with my Cyrorig M9i Cooler?
Any help and feedback is appreciated, tempted to pull the trigger on one of these bad boys soon since they have rebates right now. (Yes one is Micro ATX never owned Micro ATX before but should be fine)
I really like the Micro ATX* (EDIT not ITX) Board more than the Other one. MSI B250M GAMING PRO
Thanks
MSI B250 GAMING M3
https://www.newegg.com/Product/Product.aspx?item=N82E16813130983
https://www.newegg.com/Product/Product.aspx?item=N82E16813130985
Thanks
MSI B250 GAMING M3
