Andrew Cotten
I was wondering if a Nvidia GTX 960, Intel core 2 duo E8500 and a 8gb ram will run games such as gta v?
How so? I’m new to all the technological stuffSlowly.
those are what I just bought, I’m on a buddget but will it not run good on anything? Or did I just waste my money?... hopefully not.Time to upgrade the whole PC really.
I bought everything separate, a buddy of mine said it was a really good processor, he gave it to me for 7 bucks. I have already had a desktop, but it was really old so I got a 500w PSU, GTX 960, 8gb ram, and that processor to replace the stuff inside. Should I get a different processor?E8500 is 10 year old hardware. If you are on a budget, there are better cpu's out there that probably would have costed the same. How much did you spend on this "system"?
Model: 07N90WYou'll need more then a new processor unfortunately. What motherboard do you have?
Okay thanks a lot.The Dell Vostro 230 only supports the following cpu's. You should be looking for the Q series. If you can use this temporarily and save up for a better system, you'll definitely need it. Also, if the vostro is a slim tower case, you'll need a low profile video card. Some 960's are, while others are not.
