Should I buy RTX 2080 ?
korwolf
I've been told 2080 is a bad graphic in terms of lifespan which graphic card should I buy? At the moment i have geforce 1070 which does not serve me very well.
_Kyle_
Well-Known Member
Price to performance wise it is not a good GPU, however it is a powerful GPU nonetheless and has ray tracing tech. If you don't care about ray tracing, get a 1080ti.
beers
Moderator
What's your actual performance expectation and what issues are you having? 1070 still plays most titles at high detail and framerate so you may be having some other issue.
korwolf
having 60 on the highest details , i can't even run gta v on low resolution for some reason idk what to do at this point
_Kyle_
Well-Known Member
Could be a variety of things. Is the GPU getting enough power? PSU may not be pushing out enough juice.
korwolf
All the games i'm playing atm works perfectly fine but for some reasons gta works really badly i can't even play on low resolution
