Need help connecting P2P in same network
ssal
I've been having problem connecting the two computers since I installed Windows 10. (The two talked to each other when in Windows 8 before).
Two laptops:
HP with computer name H; Toshiba as T
Both belong to same workgroup WORKGROUP.
Both network discovery turned on and set to nearby computers to share.
They don't show up in Window Explorer.
When I tried to map the other computer (for example mapping the HP from the Toshiba), I entered \\H\Pictures (Pictures is the folder which I had set to share in properties). Then it asked me for my Network Credential.
I entered my log in name, or email and my login password. It doesn't work.
1. What and where is my network credential?
2. If I forgot it, how do I reset it?
Thanks.
Cromewell
Administrator
Try with the IP of the machine. i.e. \\192.168.0.12\sharename I find the windows discovery to be terrible, even with firewalls off. You'll also need to set an account on the remote machine that has permission, or disable the password check -> Control Panel > Network and sharing center > Change advanced sharing settings > Check "Turn Off password protect sharing" option.
ssal
There is no such option in my setting.
