Need help connecting P2P in same network
Discussion in 'Computer Networking and Servers' started by ssal, Jan 24, 2019.
  1. ssal
    ssal Member
    425
    I've been having problem connecting the two computers since I installed Windows 10. (The two talked to each other when in Windows 8 before).
    Two laptops:
    HP with computer name H; Toshiba as T
    Both belong to same workgroup WORKGROUP.
    Both network discovery turned on and set to nearby computers to share.
    They don't show up in Window Explorer.
    When I tried to map the other computer (for example mapping the HP from the Toshiba), I entered \\H\Pictures (Pictures is the folder which I had set to share in properties). Then it asked me for my Network Credential.
    I entered my log in name, or email and my login password. It doesn't work.
    1. What and where is my network credential?
    2. If I forgot it, how do I reset it?
    Thanks.
  2. Cromewell
    Cromewell Administrator Staff Member
    15,320
    Try with the IP of the machine. i.e. \\192.168.0.12\sharename I find the windows discovery to be terrible, even with firewalls off. You'll also need to set an account on the remote machine that has permission, or disable the password check -> Control Panel > Network and sharing center > Change advanced sharing settings > Check "Turn Off password protect sharing" option.
  3. johnb35
    johnb35 Administrator Staff Member
    41,325
    You can also try setting up a homegroup as well.
  4. ssal
    ssal Member
    425
    There is no such option in my setting.
  5. Cromewell
    15,320
    The advanced share setting is on the left side and password protection is at the bottom. It may be hidden in a collapsible section.
  6. ssal
    ssal Member
    425
    Am I in the right screen? Where?
  7. johnb35
    41,325
    Its under all networks, click on the down arrow on the right to expand it.
    Cromewell likes this.
  8. ssal
    ssal Member
    425
    Thanks.
Share This Page
