Cooling fan for my PC
Kagome100
SO my fan thats inside the top part of my PC went out. It's a 190.5mm size corner to corner fan that glows blue. I want another of the same but I can not find one at all... Is 190.5 the right size I should be looking for?
Darren
Moderator
My geometry skills are failing me or I'd be able to tell you the actual size. But no it's not you just need to measure across (not diagonal), one corner to another adjacent. Likely 120mm.
Cromewell
Administrator
edit: my own bad math. 97.6mm...I'm going to assume a slightly off measurement and saw 100mm fan.
I'd trust remeasuring a straight side first though :)
