This is an old PC that I'm upgrading the most important parts:
mobo: Asrock X570 Phantom Gaming 4 (at latest BIOS (2.30) New
GPU: XFX Radeon RX580 Black Edition 8GB (second hand from eBay)
PSU: EVGA SuperNova 750 G5 New
RAM: G.SKILL Aegis 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 New
When I first try to install the OS (Win10) the pc worked until the OS automatically install a GPU driver. I decided to reinstall win10 again but to make the os not to automatically update drivers so I could update the OS to the latest updates so I could activate the OS from my Microsoft account. I did all this because the AMD website suggests that the OS should be at the latest updates before installing the drivers. Everything worked until I installed the latest AMD drivers for my new mobo and the GPU. After installing them the video signal stopped and the keyboard and mouse also
turned off or could not wake the screen. The only thing left to do is a reset and then it worked for about 3 minutes or less. What do you think is the problem?
Link to PSU tester results. (Is it bad?)
http://imgur.com/gallery/pOPH5vW
