Hi I have 3 questions about Windows.
I sometimes have a problem falling asleep on my desktop PC. I will put the computer to sleep. It repeatedly wakes up differently, for example, after 30,60 minutes or even longer. I figured it does running google chrome which lets windows pop up and you wake windows. Closing it sometimes makes it steady, but it still wakes up. Sometimes the computer is suspending and wakes up when the screen is dark after a few seconds. I stepped out the options but I don't know what it can be. It helps restart and with a freshly started system when no folders are running in the background, the Internet browser is a click, but otherwise I have no idea what it can be.
2. Windows 10, I have 25Gb of free space, over time when the computer is running and I put it to sleep it completely runs out of free space. I do not get it. And there is nowhere to release it. It helps to close everything, eventually restart and place them.
3. On a laptop where I had Windows 8 /8.1 as soon as I switched to WIndows 10 it starts to angry the touch screen. When I turned off the touch screen everything was fine. When I returned to WIndows 8, everything worked again, including the touch screen.
Thanks for the advice
