How to install water cooling on my motherboard
Matoo
I have MSI A320M PRO-VD PLUS motherboard and i want to insall watercooler Cooler Master ML240L RGB. I have 1 problem i don't have pump/cpu-out header. Where i should plug pump to? I thought, idk if i should, but i want to use adapter sata power to 4pin to connect pump and use cpu-fan header for fans on radiator? Should i do that? Is it safe?
Because CPU temps on high load goes up to 80-85 degree. Now imagine summer when its 35C outside and i don't have air conditioner.
Doesn't exist anything about water cooling on motherboard manual that's why i'm asking on forums.
Yeah its bottom-bin motherboard, but i can't afford better, i even bought 1 of a cheapest water cooling solution.
